Just got boat, need motor
Bamaman1
Re: Just got boat, need motor
I have a friend that worked in the GM foundry that cast all the engines for Mercruiser. He said Mercury spec'd out the cast iron, and it was a different metal makeup that what GM used on the 350 engines. They'd come in a couple of days per year--and supervise all the engine castings. Mercury takes them back to their facilities to do the machining and assembly. These are not Chevy motors, in reality.
Marine engines are stressed substantially more than car engines, and they use special high torque/low RPM camshafts. Some people on this forum will tell you that the motor mounts, etc. for Mercruiser are the same as for a Chevy truck. I'd tell you to pull your engine before you buy any truck engine--to make comparisons. There again, some truck engines are hopped up so much that they can hold up to the stresses imposed in marine use.
I personally would look on EbayMotors.com for a marine engine--or on other internet websites. Your boat is rather aging, and the older outdrive units are best not pushed with too much horsepower. You really don't need to overspend on such an old boat.
Another issue is whether there are any soft spots or deteriorating structure under your fiberglass--a very common problem on fiberglass boats. Make sure the hull is 100% before you go repowering it.
Silly Seville
Badbowtie, you and I are practically neighbors. The wife and I split our time equally between Monroe and Brookville. I am doing precisely what you are attempting as we speak, (350 repower/cabin cruiser) and have a wealth of info for you. Send a PM my way and we can chat.
Ayuh,.... Havin' had my fingers in Many of these motors,...
I can tell ya they Are in fact, pretty much exactly whatever Chevy was puttin' in pickup trucks of whatever vintage ya wanta talk about....
The Part Numbers tell the story....
And,...
I've never seen Anybody here claim the Motor Mounts are the same,...
Actually, the motor mounts are VERY Different, Not even Close to bein' the same...
badbowtie
Well just a update I have the motor all striped and ready to come out I am going to go to my dads work on saturday and use the forklift to pull it. I also still have not decided what to do about a motor. I have located a couple new style blocks but nothing I need yet. I may locate a bare block and use my internals or buy a marine rebuild kit from a couple guys on ebay.
badbowtie
Well I just pulled the outdrive so I am ready to pull the motor and noticed a crack in the gimble housing you can see it in the pictures. i am not sure if water leaked in next to the dhifter from a bad gasket tight there and froze and cracked it also. There was no water in the bellows and no signs of water from the grease. I am not sure looks to be cast and not sure if these are able to be tig welded or do I have to replace the housing. So atleast so far I have to replace motor and the gimble housing or weld it if it can be done I hope the outdrive is still good. When I pulled the drain for the oil it was oil atleast and did not see any signs of water. Here are some pics to see what I am talking about. Is there a how to remove the gimble housing on here some were I have never removed on before.
badbowtie
I got the motor out today and when I got home I went ahead and got it up on the motor stand. I pulled it all apart and I have 30 over pistons so for the best / cheapest way should I find a good block have it done 30 over then use my pistons, rods, crank, cam, and lifters and replace all the bearings and reassemble. Or buy the block have it 30 over and buy this kit which is going to be the best way to do this.
http://www.ebay.com/itm/GM-350-5-7-Complete-Marine-Engine-Rebuild-Kit-1968-1985-/260653554551?pt=Boat_Parts_Accessories_Gear&vxp=mtr&hash=item3cb0299b77
badbowtie
Well I just picked up a motor tonight so know on two switching oil pans and and intake and a couple other things including I guess brass freeze out plugs. It is a gm crate motor that is a 350 290HP
