just had one hell of a shock
slate1234
I went out yesterday useing my 6hp johnson model number:J6BACTA,on a 3meter sib when I got home I was flushing it and thought I would check it was running on both cylinders ,,,,,,pulled the lead of the bottom cylinder and got one hell of a shock,so what would cause this and how do i fix it
tpenfield
Re: just had one hell of a shock
electricity causes the shock . . . there is no fix.
slate1234
should i not change the plug lead or coil to prevent this happening ?
Howard Sterndrive
to prevent this from happening:
stop touching spark plug leads on running engines, or wear thick gloves (still no guarantee)
there's 20,000 volts there - it goes where it wants, and you are as good a path as any
seahorse5
Go out to your garage or driveway and try the same thing with your car's sparkplug lead while it is running and see if that shocking sensation happens also.
If so, then you may need professional help which we cannot give you here.
phillnjack2
Ensign
ha ha ha professional help ha ha
how on earth do people expect not to be shocked ??????
if it didnt shock you then you have a problem.
im looking down the barrel and im now gonna pull the trig....................................................................................
phill
im guessing you have done this before slate and have not been shocked. electricity follows basic rules and one of them is the path of least resistance. so standing in a fiberglass boat in rubber soled shoes and making sure you are not with in 1/2" of anything metal you can pull a plug lead and not get the crap knocked out of you. its realy a dangerous way to test the engine as you have found out especially if you add a little water than all bets are off. you can buy plug pliers that are rated to protect you from the spark to carry out the test. on muti-cylinder engines you should never touch the leads or caps while the engine is running with your hands as you may not be able to break free until it runs out of gas or you pass out. the best way to check for lead and cap leakage is to run the motor at night time as you will be able to see the sparks jumping from the leads. if you learn something from the experiance then welcome to the club
slate1234
ye well I wont do that again in a hurry next time the her indoors can do it for me lol ,,I will try starting it later when its dark to see if the spark is jumping to anything other than me
phillnjack2
Ensign
if you get her indoors to hold both plugs while you start it up, she can have a very cheap and very quick perm.
save a fortune on the hairdressers.
phill
slate1234
hold the leads she can kiss them ,,,,,,after dinner is cooked of course lol
slate1234
I just went out and started it in the dark and all seemed well no spark jumping anywhere so all seems good, thanks all
kfa4303
Banned
You're supposed to get your buddy to do it for you and laugh at him when he gets shocked. You can also use rubber handles pliers, but I would advise against it. Spark plug testers are quick, cheap and easy to use and don't hurt nearly as much.
slate1234
yes I got one today and there both fireing also did a compresion test both at 95 so all seems well and learned a bloody good lesson lol and a few of you had a laugh so good day all round lol
kfa4303
Banned
ah well. live and learn. sounds like you've almost got her running again. compression is the most important issue. all the rest can be fixed with relative ease, and it sounds like the spark is fine, which only leaves fuel. that generally means a carb cleaning/rebuild.
slate1234
no no no its running, I was out with it yesterday it just seems slow it's pushing a 3meter sib and 25lt fuel tank two rods and tackel bag, i recon the prop next but what size is anyones guess ?????
kfa4303
Banned
I see. Well lets do some conversions into proper units ;) (3 meter = 9 ft. boat, 24 lt. = 6 gallon tank). I wouldn't expect speeds much above 15 mph, if that. However, you may want to experiment with the trim/tilt as well as the motor height. I use a tiller extender on my motor that allows me to move for/aft as needed to balance the load. It's just a piece of PVC with a few slits in one end to allow it to slip over the stock twist grip and help in place with a few pipe clamps. I love it. It cost practically nothing and it also allows me to stand while underway. Here are some vids of rigs similar to yours that may be helpful and give you an idea of what to expect.
http://www.youtube.com/watch?v=A5wvndeaJ7s&feature=related
http://www.youtube.com/watch?v=vEQ1IOVYFuE&feature=related (DO NOT operate motor the way this kid is. you should be seated on the bench on the other side of the tiller)
http://www.youtube.com/watch?v=yG12tfUKsL8&feature=related
slate1234
Kfa4303 thanks for that mate, in the last vid that boat is running sweet my engine does not seem to rev that high,I have posted a question in the prop section but not had any replys,I think I need to change mine,there are no markings anywhere on the prop I have, I will take it of today and put a pic of it on here
and thanks again
kfa4303
Banned
Hello again Slate. If you're not getting the speeds seen in the vids, I would double check the spark and/or compression. These old motors can/do start and run surprisingly well on only cylinder. You should get a nice "snapping" blue spark from each plug, capable of jumping a 1/4" gap with ease. Assuming the spark and compression checkout, all that remains is fuel. The prop looks stock and appears to be in decent condition. I doubt that changing it would make much of a difference. However, if you remove the prop and look on the backside of the hub, you should find a part number stamped on to the part. What year is the motor by the way?
slate1234
hows you KFA4303, motor is a 1983 model number :J6BACTA I will pull it of in min and have a look,I did a compression test they both came out at 95, I also got a plug tester coz theres no way i'm pulling them mothers of again and both fireing good, I have however got the wroung plugs in so I have got new ones on the way
