Re: Just put rebuilt heads on the motor and fired it up... what's that sound?
I agree with checkmate. If you replaced the head gasket properly it really wouldn't just blow out like that. And if it is a gasket problem again, you have something else going on in there... Head gaskets usually fail because of some other factor like water in the cylinder, warpage, or not properly torqued... Check everything before you take that head off or all you'll accomplish is spending more money on a new gasket set. Check the heads good too. I've seen water passages rot all the way through to the valves! Start with the basics, and check everything.
