ONERCBOATER
- Oct 11, 2010
- 536
20 ft tracker pontoon, 20hp 1978 merc 7p 3 blade= 5500-5600 rpm and about 12 mph.
now i doubt that most would consider this sufficient power, but it easily pushed me against a 19mph wind, and though slow, was remarkably efficient at 3500-4000 rpm. You also have to consider that there is a 10ft cabin on the boat, 4 240lb people and a 3 yr old (39lbs) 4 deepcycle batteries, 3 coolers. The reason I even bothered posting this is that i have heard people repeatedly point out it isn't enough power... the actual answer is depends on how fast you want to go, how frugal do you want to be.
Hope this helps someone with a marginal budget who simply wants to put about without worrying about a large gas bill.
Sean
Sean
