robinfla52
- Oct 13, 2009
- 47
The above motor was set up for electric remote start but I didn't get harnesses or key switch with it. I replaced solenoid. I got a harness but not sure if it is for Mercury, even though description and part # is same. Has 7 pins. See pic. Got a key switch asy. There is no yellow/red wire on motor. I can bypass solenoid and it fires up, but when I use switch nothing happens. See more pics. Voltage is good all around and I get 12vdc on yellow/red on the switch. I get continuity to ground on the right hand bolt that goes to starter. Could that be the issue, but why?
