393Clevor
- May 18, 2019
- 209
In the final stages of getting this old girl ready.. I am missing the motor plug part of the controller so I just hacked off the end of the harness coming from the controller.. this is what I have figured out so far... ,where I get stomped is this kill switch part of it..
I got the main power (red) hooked to the (+) side of the solenoid, Purple/White to the electric choke, Yellow and red to the starter solenoid, Black (-) ground, Purple is a key on hot wire (+) must go to the gen or rectifier, Black/Yellow seems to be the kill switch in the off position it's grounded.. there is another wire a gray one that just goes thru to the pig tail connection and a brown wire that goes to an alarm inside the box
what has me baffled is this cut out switch.. I need two ground wires to kill it, the way it is now with just one kill wire it only kills one set of points..#2 is still sparking and it is connected to the cut out switch... Do they kill these engines with just one cylinder?.. seems I need a controller with two keyed grounds to kill both cylinders.. what I'm I missing?
