boaterlady
- Jan 6, 2015
- 66
Ok, sanding now and there is like NO dust. This is awesome. Honestly no need for the suit. Also, things look better than I thought will show pics
30 photos now, lots of angles and shots to look at, will get to inside soon enough. What more do I need to post? Trying to get this done. Pictures still not enough? Patiently waiting for responses. Thanks
I have a gallon of epoxy I would like to use and then paint over gel.
Ill say again, she looks ok inside I think, there are some wood seating areas we would like to replace when need be but I should point out this is not the boat we will have for ten years. This is a practice boat to enjoy for maybe 3.
The goal is to learn to sail, learn about sailing boats and repair so in 3 years we will sell the house and buy a bigger one to sail to Australia, my homeland. I do not wish to spend thousands more gutting her. I would also like to get her going asap and fix more things as we go along. The foam covered beams in the front part I can see and they seem ok, Am i expected to rip up the whole floor to see everything? That seems overwhelming. What should I look for? That maybe easier.
deep blue you are so helpful thanks!!!!!!!!!!! and others too but he gets an honorable mention. In regards to painting since you asked, I want to use blue water signal yellow. Then a black strip on top, black bottom paint. I will post a photo of another boat like mine.
I was thinking I can use the epoxy resin on the gelcoat and it says fibreglass as well, sand and paint over it. There are some spots where the gelcoat is thinner so you can see fibreglass under it and has scratches etc. My thought was filling and making those spots even to the gel coat with the epoxy resin.
