Leak from water distribution housing
new_2_boats
I have a leak from my water distribution housing. Does anybody know what's going on here? See video.
  • PXL_20230525_185942077.TS.mp4
Bt Doctur
No video, but I suspect the housing either crackesor the crack is at the blue drain plug.Cheaper to replace it with some copper fittings
Let me look for the pic
Bt Doctur
What you have is called the "Quick-Crack" system Suggest removing that system and revert back to a standard drain system
alldodge
Agree use BT's copper fittings and it won't happen again
Fella at my dock replaced the thing twice before he started just leaving the drain out of it during winter. Appears the system never fully drains and if plug is reinstalled more water leaks into it later and cracks it
muc
"Retired" Association of Marine Technicians...
Yup, I’ve replaced a few of these. Always because of bad winterizing. If you can’t do it properly it’s probably best to remove the system.
Also a bad system in saltwater, really want closed cooling in salt.
new_2_boats
Do you know if I can purchase these copper fittings from someone preassembled? Can I do this repair in the water?
muc
Don’t know about a premade kit. But it can be done in the water once you break the vacuum by removing the blue plug on the thermostat housing.
new_2_boats
Could you tell me what size/type of copper fittings these are and how to assemble? I would love to swap this out on my boat. I don't want to replace the water distribution housing with another piece of plastic.
alldodge
Suggest PM BT and he can fix you up
Bt Doctur
From memory, start with a 1 inch "T" a short 1 inch vert section 3-5 inches long, a i inch "street elbow" and 1 inch coupling on the right. On the left a reducer from 1 inch to 3/4 .
PM me an address for the bushing that accepts the 1/8 pipe plug for draining
On the bottom solder it in place first then drill the drain hole, then screw in the plug
Trim rubber hoses to fit
