I have a 1986 Tide Craft bass boat and I am having problems with too much water getting in the bottom between the floor and hull. All the plumbing seems to be connected and the live wells seems to be ok. I have checked for holes and damage to the hull and it doesn’t have any leaks. I am attaching a picture of the back of the boat for you to see. This is the only area that has ports beneath the water level. Can you give me your opinion on this I cannot find a owner’s manual on the boat. With it taking on the water I can’t get the boat to plane and run right the engine is struggling and it has a 90 hp Evinrude on it. On the back of the boat you will see the drain plug, two ports for live wells and the two black vents what I have no idea what they are for. It would much help if I had a manual but I can’t find one. Please help!!!!
I have looked all over the internet and your site is the most friendliest and easy to use, if you can give me any ideas I would appreciate. I am just about to the point of removing the two ports in the back and filling my live wells manually and then draining in the bottom when I remove from fishing and drain thru the drain plug, at least that way I would only have what water is in the well and not constantly putting water in the bottom the whole time I am fishing. The only way I can keep it out now is to turn on the bilge pump and pump it out. This driving me crazy and I can’t get the performance out of the boat the way I should.
I have filled the live wells manually and can’t find a leak I have ran water in the two ports and it goes to the live wells and will drain back out the same way and again like I say if I had a manual on the boat it might help. I really like this boat and I hope you can help me, if you think I could remove the two ports and fiberglass and seal this area on the back I can do that and leave the plumbing inside the hull to drain the live wells if this would eliminate leaking it might be worth my while.
Again Please help me with this problem after screening your site I know you are knowledgeable of these things.
The last time I ran the boat i bet i drained out 15 gal. of water when i loaded it on the trailer, this is making it run bad and will get on plane.
I have added a picture i am sure the two white ports are drain and i figure the two black is for my live wells.
