Re: Leaking boat
I will pull the engine so i can get a good look at the transom through the engine bolt holes if it looks good i will make sur eit is dry. I will also remove all thru hull fitting and clean them and reseal with 3M5200. Is there any particular I need to use where the engine bolts on. I have a strange feeling that I am going to find maybe holes that hollowed out from wear. If i do this i want to make sure i do it right. Also if my engine is not running proper will that have any thing to do with water finding it way in. I know I am going to have to tune it up before it backs to the lake.
I am having problems getting the speed I need to get the boat to plane. I have checked the prop and ny book calls for a 13X17 it has a 13X19 on it and it is a 90 hP Evirnrude, I will do a good tune up on it I know from the reading i have done the prop is a important factor in the handling and the speed of the boat.
