Leaking gas at tank
jerkputter
I have a 20 foot pontoon 2000 year model with a 50 HP Mercury that now leaks when I prime the bulb around the connection at tank. It is the 5/16 barb fitting with the quick coupler. It has a small o-ring inside the connector that is bad. I think maybe the o-ring could be swelled a little. Was wondering what size o-ring to buy for this? I just pushed the ball back in the coupler and removed the o-ring to remove. I have an o-ring set but this one is has a larger diameter than the ones I have. Thanks
old jim
Re: Leaking gas at tank
Maybe it's time to replace the coupler, hose, and bulb. especially if it is all 2000 vintage. Regards, old jim
gpfishingdude
I had one connection that was leaking because this hot weather is causing a lot of pressure in the gas lines. I cut and clamped the leak but it started leaking at another fitting until I loosened the gas cap. Fixing or replacing gas lines just wasn't on my schedule for the day.
