LED lights
MH Hawker
well my reasons for changing is more about durability, the set that i am replacing is optronics incandescent when i got my present boat 6 years ago i went though ever thing it was a Kentucky trailer so the lights didnt work at all and i was missing fishing time :D so i grabbed a set at advance and hit the lake and after 6 years one of the rear side marker bulbs is out, not complaining about that, just that the newer LEDS will last longer and yes a bit brighter all ways helps and being as i was re building my trailer why not
MH Hawker
the lights made it in today and i got them installed but the 1/4 carrage bolts nuts and flats are plain plated hard wear so tomorrow i will make a run for stainless, other than that its good their real bright so seeing them in full sunlight should be easy, thats my main reason to change
Pusher
I decided that a $20 submersible incandescent from O'Reillys was a better deal than a $65 sealed protronics from etrailer. Thanks goodness because I munched both of my lights three weeks later. $20 and I was back in action.
JASinIL2006
I bought LEDs at O'Reilly's to replace my incandescents. Not very expensive and they are much, much brighter. Installation was about as easy as can be - pop out the old lights, pop in the LEDs. Easy. Inexpensive.
MH Hawker
the install took about 15 minutes per side and i even soldered them and i used PVC tape instead of shrink wrap, i like tape because its more padding
MH Hawker
yes thats what i replaced, i have noticed a lot of the newer trailers with LED are plain easer to see during the day time and i have been doing a rebuilt so it was more of a case of why not up date
Pusher
I'm rebuilding too. Munched them backing up in the gravel lot. Some of them are really bright which would be nice but generally speaking I don't miss a 7' wide boat stopped in my lane so I passed on the extra $40 to help out the guy that's going to run into me. If the $60 wasn't a factor I'd have bought LED though.
roscoe
Had 2 sets of optronics, one set was junk, lots of dead less in a year.
The second set ( the good one) are starting to lose led's now.
Had a set of blazers, good, but sold the trailer 4 months later.
Got a set of Wesbar, about $90, they have been great for 5 years.
MH Hawker
wesbar is what i had, and i think thats OEM on most trailers, my set was 45 through amazon, so far the lack of stainless hard wear and the wires were a gage or two smaller is the only thing i have noticed and i am sure the wire gage is due to the smaller current draw, i will have a picture tomorrow, it was to hot for me to be out side long today, i drilled a hole in the light bracket and wire tied the loom at the end of the new light to stabilize it
MH Hawker
if you have a moment take a look at my rebuild thread, the paint mix is spot on for a glass finish with a brush a and roller and a special thanks to GM 280 and Wooden Glass for the help,
my trailer is 102 wide, 8 1/2 feet x 28 long so any help is nice and most of my tows is on interstate, :facepalm: or like the trip i am planning Monday its going to have about 10 miles of broken pavement, road slips, and it looks like a bunch of WZS all hooked together, typical WV mountain back roads, we have rented a cabin for a few days
MH Hawker
LED 1.JPG got the hard wear this morning and finished it up and 2 pictures, i used SS ny locks flats and carrage bolts and 2 flats on the ground and a touch of nolock to retard rust , you can see that it came out a neat install
