williampmccarthy
- Jun 17, 2009
- 3
What I would like is to have position 1 the start battery, position 2 to be two house batteries in parallel ( stereo, lights, inverter, etc).
I've been reading and if I use the simple "1-2-both-off " switch :
1. if I run my house battery down very low and put the switch to both the voltage from the full start battery will rapidly discharge to the house batteries possibly causing an explosion
2. If I switch to off while engine running the alternator will be damaged
3. That the alternator only works well if both battery banks are of similar size and make up..ie one start battery and one or two deep cycle are unbalanced and the charging of both banks together will be hard on the batteries and alternator.
this link is a dialog of a vehicle wiring, but references boat wiring
http://www.pirate4x4.com/tech/billavista/dual_battery/my_dual_battery_setup.htm
I find some products on the net and on this sight for several different setups, but can some one please give me a little more insight on the issue.
I've also been reading that my standard alternator on my 5.0L merc will probably not be sufficient to keep all three batteries charged.
I'm pretty sure I've already damaged my alternator with the current switch...at least that's what autozone says.
much thanks for any advise, products, diagrams, specs....Bill
