I have a 2003 LF225 that gave me a overheat alarm. Put a waterpump kit in and replaced thermostats. Will not pee water while on muffs or in 55 gal. drum. Wouldn't discharge water before I replaced parts. I traced the discharge tube back to where it goes into what I believe is the rectifier cooling block. You can blow through it and it appears to be clear. Any help or suggestions would be greatly apprecieated. Motor has 940 hours and been well maintained...
