Re: liberator 211 rework
Looks great!, Keep the pictures coming. I forgot to take some pictures last weekend when I was winterizing.
Question: I had a drain plug on the Port side of the block, but could not find one on the starboard side of the block. The port side one, as well as the exhaust manifold drain plug, were both blue and could be removed without any tools. They were twist out...
On the Starboard side, in the same place as where the port side one was, was something that had wires coming out of it. Almost like a temperature sensor. Have you guys seen this? I wasn't sure if I was supposed to remove that or not. I ended up pouring non-diluted anti-freeze into the hose that connects the water pump with the thermostat housing. I kept the water pump side connected and continued pouring until anti-freeze came out the thermostat housing. Think I need to do it again, and pull that other plug, with the devices with wires connected to it?
