lifting ring or eye.
kbh121956
Hello everyone. Looking for a lifting eye for a 75hp Chrysler, flywheel is removed. Anyone know where too buy this tool? Thank you.
alldodge
If you know the thread size, look for eye bolts or lifting eyes. Find at Grainger or MS Direct and others
Jiggz
For all practical purpose, you will be better off lifting the motor through the flywheel. There are three pull out bolt holes that you can use with eye bolts and chains to lift the entire motor. And then of course, there is also this fabricated tool by the late Frank A.
jerryjerry05
I have used an L bracket when the flywheel was still on.
Then I have used a small loop chain if the flywheel is off.
Just remove 2 screws across from each other.
But be careful and don't crush anything.
A factory manual will have the tools listed.
It should include a lifting eye.
I finally bought one.
