- Jul 23, 2011
- 51,726
ok, Folks, lets re-set with the same information
if you read all the threads
OP just bought the boat - OP lives in Florida
Boat is a restored 1977 Aquasport 222 (quality of restoration unknown)
the motor will go to 4800 RPM at WOT (speed at WOT RPM unknown)
OP is obsessed with 3800 RPM/18mph point (reason not given)
Motor is a remaned 350 running a DUI ignition and Holley carb (650 CFM 4175 spreadbore)
Base Timing of 10 degrees BTDC and a 25 degree advance
Idle set at 600 RPM
drive ratio unknown
drive type unknown (assuming inboard gear)
prop unknown
tach unverified (need to compare to known good tach)
speed unverified (need GPS speed)
My guess is that this is the boat https://www.popyachts.com/center-co...sale/aquasport-222-in-lakeland-florida-140750
if that is indeed the boat, it is an inboard
Cruise speed listed in the ad at 18mph
that speed at that RPM is a function of the hull, prop, gear ratio and RPM and has absolutely nothing to do with weight (until you add so much weight the boat sinks). So the OP removing the tower, etc. would do absolutely nothing to the speed at that point.
In order to determine if the correct prop is on the boat, a WOT RPM run needs to be taken
Idle set at 600 RPM
drive ratio unknown
prop unknown
