Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
how is the best way to replace a live well line under the hull,it is leaking between the bow and the transom ,it is a 1984 17 1/2 ft. stratos bass boat.
leebob<br /><br />Disconnect both ends. Tie a piece of rope that is longer than the tube to one end.<br /><br />Pull the tube out.<br /><br />You can fish a new tube in with the rope that is left behind.
it worked ,had to take a hose pipe and blow out some foam ,besides that worked fine (a lot better than separating the hull ,thats what i was going to do this winter.) thanks a bunch...leebob
