Livewell and Storage
poolshark38759
i have a 14' PolarCraft Jon Boat that has a rear bench and a front deck in it..i have extended the front deck about a foot to gain some leg room... it has no livewell or storage in it... i would like to build a livewell and storage area for it and also install a stick steer setup here at the same time... boat came with the mounting brackets for the steering...i have also installed a wood floor...i have already purchased a control box for my 75 25hp Johnson OB... any one know where i can get a good used stick steer setup...post back here or email me @ prmullinsjr@highstream.net..<br />thanks..<br /><br />what is the best way to do this???
poolshark38759
Re: Livewell and Storage
guess no one has an idea...i was thinking of just building a rectangular box and putting liner and areation system from bass pro....
I can't help you in your quest,<br />But, I Question the amount of Weight you're Adding to such a Small boat.........<br />You're going to be Over-Loaded, Before you even step into the boat........<br />Center of Gravity is Another Issue you'll need to deal with.......
poolshark38759
what about adding foam under the flooring....it has foam under front and rear decks... i dont think i will be over weight as i had one of those portable livewells from cabella's in it but it doesnt hold enough water...<br /><br />thanks anyway!!
Water is about 8lbs. per Gallon.......<br />Foam Does Not add Floatation, it adds Weight.....<br /><br />Do the Math....<br />It Looks like you're adding a Bunch of Weight, in a Very Small Boat......
