recently purchased lms 332c. in running the cables to the unit i find that the extension cable is not the 25' y-adapter cable but a single cable. the length is good enough, but the end does not mate up at the unit (female to female).<br />the y-adapter is supposed to have a 60ohm terminator for use with direct connection (which is the way i'm doing it). in a seperat bag in the box thereis a plastic T with a 60ohm terminator (not attached). can i attach the terminator to the T, and use this piece to complete the cable setup? using this method will allow me to connect the cable.to the unit.thanx in advance....Bill<br />.
