Don S
- Aug 31, 2004
- 62,321
Re: Location of MerCrusier Timing Marks
Is your flywheel rusty, and maybe your vibration dampner on the front of the engine?
Is it the same on both engines? Do both engine turn the same direction?
To be quite honest, if this was my boat, I would get one of the adjustable timing tabs, and a piston stop, and make my own accurate timing marks on the vibration dampner and the timing tab on both engines. Then set them to Merc specs for the 5.7 MIE engine from the OEM service manual. You can borrow my manual if you want, Click here to download it.
While the OEM manual doesn't show how to adjust the timing on the flywheel, it may be a SeaRay setup. Merc did a lot of special stuff for Searay in that era that may not show up in a Mercruiser manual. Similar to what Glastron did with Volvo engine and drives.
