Looking for info on my 72 merc 1350
gotboostedvr6
It's a 72 with tilt/trim and quicksilver stainless peop
I'm not sure if i have an interest in running it unless it's worth fixing the one low cyl.
What would a used powerhead cost?
is it worth me parting it out?
Here are the pics:
Scaaty
Re: Looking for info on my 72 merc 1350
Whats the pitch on the prop? I might be interested..
The rest? Jezzz, power tim motor alone worth a bunch, PT/T cylinders go for $300 ebay...controls worth $300..part it out will get ya a darn good buck, (lower, wraps, middle section, (looks like a shortshaft) ignition..
re-doing the block is a better idea though, but it is junk. Basically the power head is trash.
gotboostedvr6
it ran fine but low rpm and mid throttle was choppy... wot was fine and spun 5k - 5100 tilt trim works fine.... how diffucult is it to rebuild these?
OldMercsRule
I agree with SCATTY. Those PT parts are worth a bunch. He just rebuilt a sweet engine similar to yours, (it looks like a 20" 'long shaft' to me, but I could be wrong). It depends on where you are and how much of a hurry you are in. A good running 115 is easy to get in Seattle in the winter for less then $500, and yer PT unit would bolt up to any 1979 or earlier, (you could also bolt it to the later models with a few more but fairly minor problems). the 1500s and 1400s and 1350s are a little more money but can be had for under $1000. I rebuilt a 1500, (and it needed new pistons and a trigger which hurt me: real bad), for about $3000.00 or a little less, (if memory serves). I bet SCAATY is into his for at least that. But once ya got the bug: it's all over. The short shafts are more rare if that is what you have. JR
gotboostedvr6
The powerhead, mid and lower are now apart ill look for a running powerhead for the next week or so but if i dont find any ill be selling these parts off
The previous owner informed me tonight the power tilt/trim unit and cyls were added in the mid 80's due to his handy cap... he only used the boat one or two times a year after that so this motor, particually the hydrolics, have pretty low hours.
The powerhead still has the factory seal on it.
does anyone have any leads to where i can find a good powerhead?
croSSed
Search on here for Clams Canino. He has every 99.8 CID powerhead ever made. He surely has a 1350 powerhead for you. From him I think they run around a grand, and if so, that is a screaming deal! BTW, your motor can't be a '72. Mercury made the 1400 that year. Yours is either a '70 or a '71. And, that is definitely a 20" shaft motor.
TG
Scaaty
Am Am I missing something here? That block looks like ya punched a rod through it or something??
Where ya located...west coast Puget Sound, I can point ya to someone..
(yep, second look says 20 inch shaft)
gotboostedvr6
these rods use a nut and bolt not just bolts
Scaaty
OK, couldn't tell much from the pic. Whats wrong with it anyway, just a low cylinder? What PSI if so? And again, location?
gotboostedvr6
top hole is down to 70 - 80 psi the rest are 120...
i dont have time to mess with it so im going to sell it
