looking for new prop
jaymz411
Having trouble finding a 5 blade stainless steel propeller in stock. I ordered one two days ago and it was cancelled due to not in stock. I am looking to get a better hole shot when pulling a tuber.
1) Performance issue you are trying to correct.
Hole shot / acceleration
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
it is aluminum 3 blade
3) Current prop diameter and pitch (required).
no idea, it came with the boat when i bought it
4) Wide open throttle RPM and speed with an average load (very helpful)
took it out the other day and it was hitting ~44 MPH @ 5800 RPM
5) Engine/drive make, model, year, and HP
2013 mercruiser 4.3L MPI 220 HP
6) Boat make model, year, length and weight
2013 hurricane ss 201
floater212
if in stock Hill Marine signature pleasure 5 blade props, but you need more info for boat.
What other info is needed
Ayuh,.... Welcome Aboard,..... Pull the prop off the boat, 'n find the numbers on it, pitch will be cast or stamped into it,....
'n yer tach is off,..... Way off,.....
Cross-check it with a known good shop tach,....
jaymz411
How does the pitch of the current prop help? It’s only a 3 blade.
jaymz411
Do you think the marina will let me borrow their tachometer?
jaymz411
I ran through the Mercury prop selector and it recommended this:
Mercury High Five (13.5" x 17") RH Propeller 48-821154A46​
Stinnett21
The pitch of the prop is how much bite the prop takes with each revolution, i.e the angle of the blade. In theory a 17" prop would advance 17" through a solid in one revolution. Water is of course not solid but this is a standardized way of expressing this dimension. Much more can be said but bottom line...pitch is very important in understanding your propping situation.
Scott06
it is a starting point for next prop selection. Your tach is off as an rev limiter will kick in at 5200 or so. What your current prop pitch is and your current wot rpm will determine what you do for the next prop.
for example if yiu are running a basic three blade like a blackmax - say 19” pitch and getting close to your recommended wot rpm limit 4800-5000 i suggest you go with an aluminum 4 blade like a 18” michigan vortex for better holeshot. I would cut your teeth prop selection with aluminum before you soend the bucks for ss . The vortex is an excellent value and cheap as far as boat stuff goes
