Looks like I'm done using Merc 2-stroke oil
SeaNymph Man
Re: Looks like I'm done using Merc 2-stroke oil
I ran my boat for the first time of the season this Sunday. As I backed down the ramp a guy with a shiny new OptiMax was backing down the other lane. He flicked his key, the engine started instantly, settled to a smooth idle and he drove away.
I choked mine, turned the key, it started quickly with a small puff of smoke. I ran it at high idle for a second and then shifted it into gear and it died. Started it again, let it warm up for a second more and then boated for the rest of the day with out a hiccup or stumble of any kind.
Having a shiny new state of the art outboard - $20K
Having a long paid for, reliable outboard that does everything I ask of it - priceless...
Amen! Old carbed two strokes all the way. Mine is paid for,too,...and no
computer chips to worry about!
special_kaye
My 37 year old 2-stroke:
Pay substantially less to acquire than a single year of annual maintenance for most "modern" outboards.
Spend substantially less than a couple of years worth of annual maintenance costs for most "modern" outboards, to rebuild all major systems in motor.
Run without further problems or substantial expense for years afterwards.
Change spark plugs once in awhile, change gear oil as needed, replace water pump impeller every three to four years.
Spend less on fuel and moderately priced semi-synthetic 2-stroke oil, than the payments on most modern outboards of comparible size.
Tow lots of guys with $20,000 motors that have "crapped out" computer chips, with 37 year old outboard that runs like a dream day in and day out.
:D alot, because "baby needs shoes" doesn't keep me out of the boat - I can do both!
Love it! One of my 2-strokes just turned 21, same age as one of my kids. So, now it's legal to drink full synthetic, if you know what I mean....
rspar
Just found out my Merc 80 was made in 71 wish me luck going to try and get it running this weekend after 23yrs in mothballs. In the inlaws garage where the boat used to be is a dozen little soup can size cans of 2 cycle oil think they're any good after 20 or 25 years?
Rickairmedic
When they make a 4 stroke that looks like my 1959 Mercury Mark 59A that matches the looks of my 1960 Cutter runabout I might think about it ( but I doubt it ) :D.
Rick
sikpnter
I have one more gallon of Merc Premium Plus from the 2 cases I bought last year at $14.95 a gallon. Went shopping to replenish the supply and was shocked to find MPP at $29.99 a gallon this year. I found Evinrude HD30 locally for $18.99 a gallon but my motor isn?t real happy with the stuff.
Found an on-line supplier of Pennzoil Premium Plus and had a case (6-1 gallon jugs) delivered to the house for $93. Went ahead and ordered a second case of Evinrude XD50 at $127 a case (6-1 gallon jugs) just in case I had issues with the Pennzoil stuff.
I just ordered a caseof the pennzoil from the oilstore and I only got 3 in case. How did you get 6? Mine ended up being 60 bucks delivered.
dingbat
I ordered 6 gallons on Friday and got 6-1 gallon jugs delivered in a single box vis UPS on Tuesday. If I remember correctly shipping was $17 and change.
Rotorfixer
Four stroke - Fill gas, turn key, leave dock, enjoy the fresh air as you motor about.
Two stroke - Fill gas, add expensive 2 stroke oil, turn key, won't start, pump primer bulb again, finally starts, cloud of blue smoke overwhelms the area, smoke clears bugs and fellow dock users from the scene, leave dock, inhale blue smoke, feel noxious all day
Yep, two strokes are much more user friendly :D:D
Wow... that is pretty bold,
How about oil and filters on your 4 stroke? Are they free? I have a new 150 Optimax and I use under ONE jug of oil for the whole year (@ 100 hrs), $120 CDN. And good luck on seeing any smoke from my engine
(but you can let me know because you would be with everyone else... behind me ;) )
Yreka
Isn't the OB in his sig a 2t ?
Rotorfixer
Do you mean mine? I'm not sure what you mean by 2t, but mine is a DFI 2 stroke......
dingbat
One whole jug a season? WOW :eek:
The problem is you have to look at the scale. On average, I burn 20-25 gallons of oil a year on the 2 stroke. Twenty five gallons of 2 stroke oil at your price is $3,000 CDN.
Two years ago I burnt 52 gallons. Would have cost me $6,240 CDN at your prices. How much did you pay for your motor?
The oil and oil filter for the 4 stroke cost me less than $100 CDN and 45 minutes of my labor to change.
Is my 4 qt oil change and filter supposed to cost more than 25 gallons of 2 stroke oil? :rolleyes:
As far as eating your dust, hardly. You would never make it past the breakers on the way out of the inlet on most days let alone pound your way through 30-40 miles of open ocean.
Tell ya what....I'll even give you a 30 minute head start. ;)
Sure, the 200HP is a faster motor. Throw in your typical 2-3 foot chop that we run and the 2 stroke suddenly becomes no faster than the 4 stroke because your speed is limited by your hull design.
Just to set the record straight, I'm running a 200Hp 2 stroke on the Grady and a 225Hp Zuke 4 stroke on a Maycraft that I?m part owner of.
Rotorfixer
I guess the point I was trying to make was that you can't just say "2 stroke" there is a HUGE difference between a DFI motor and an old carbureted one. You can't compare prices of oil either, completely different.
Looking back on my post I realize how it came across, my statement about being behind me was in regards to the difference in performance of 2 stroke vs. 4 stroke, specifically the hole shot, apples to apples a 2 stroke will accelerate wayyyy harder than a 4 stroke, so yes if we had the same boat, same power, the 2 stroke would "out perform" the other boat (except for noise levels of course) I was trying to illustrate some of the advantages that 2 stroke has over 4 stroke, and of course the same could be done for the 4 stroke. There has to be a reason why we are spending $20,000 on these motors.
I guess another advantage is less weight and less moving parts (typically).
Sorry if the post seemed arrogant, I guess I should have explained better what I was getting at.
(by the way, I live on the largest lake in Alberta, the biggest waves I have seen so far were 12 ft (during a fishing tournament I was in, 2 boats were lost), average day is 3- 6 ft, normal storm is 7- 8 ft (all measured by sonar) because of the wind here (a few weeks ago a 300 HP 21 ft was sunk during a tournament, one man on the team died). So as far as handling rough water, I am somewhat used to it, and my boat does 50 MPH GPS in true 2 ft chop on step) Am I trying to say my boat is great for the ocean? Not a chance, I would not take it through 40 miles of open ocean, it's not built for that like yours is.
Again, I am not saying 2 strokes are the best, it all depends what you are doing. I was just trying to paint the other side of the picture which nobody was doing!
by the way, how many hours do you put on your motor with that much oil consumption? just curious. :confused:
Peter.
dingbat
Peter.
It's not the hours it's the distances.
We run a minimum of 30 miles each way. If you have to go to the canyons you're looking at 60-75 miles each way. That doesn't include trolling at 10-12kt once you get there.
I carry 147 gallons of fuel onboard. Can easily burn 90-100 gallons a day. That's $50 USD PER DAY in oil.
Rotorfixer
Wow, that is some serious boating! I do miss ocean fishing but I would be scared to take our boat out there......
Peter.
dingbat
So do you still belive the BS that the cost of the oil and oil filter balances out the cost of the 2 stroke oil? ;)
ondarvr
The "uses less oil", or "lower in cost" claim was made for E-Tec OB's and no others, they inject oil in a different manner than most others and don't require a lower unit oil change for three years, which can lead to using less oil than a 4-S (at least in their claims). I'm sure for comparison they used the 4-S with the highest cost parts, most frequent recommended oil changes and list price for the service at a dealer. If you take your boat to a dealer for all maintenance and pay list price for everything, then this comparison may apply to you
Almost all other 2-S's use a 50-1 to 70-1 average, DFI or carbed makes no difference, although the DFI models use less fuel over all.
Rotorfixer
Are you serious??? You have a Suzuki 225 four stroke, you should be changing your oil and filter every 6 months or 100 hours, how is that any different than the $100 I spend on oil for the same amount of time ????? Unless you are telling me that you do not change your oil as often as you should, which would be ridiculous.
And to the person who said E-tec only, they both burn the same amount of oil, the E-tec happens to have a lower EMISSIONS rating (CARB 3 STAR) Optimax is CARB 2 STAR. The optimax still uses less fuel and is quicker than the E-Tec, the E-tec however has many nicer features like self winterizing, requires less maintenance, is quiter, and has fewer moving parts (specificaly no air compressor for the orbital injection system).
"Almost all other 2-S's use a 50-1 to 70-1 average, DFI or carbed makes no difference" I'm not sure where you are getting your DFI info, but I am afraid you are wayyyyyyyyy Off, mine runs as low as 400:1.
ondarvr
As low as 400:1 means nothing, its the average that counts and it will be far higher than that, plus I didn't say "every" I said almost all, so if your particular motor doesn't fit in the "almost all" group then don't get offended.
If you run at low speeds all the time then the oil consumption will be lower, running at high(er) speeds on a continuous basis will use much more.
Show me where its claimed that your OPTI uses the same amount of oil as the E-Tec, plus if the E-Tec gets better mileage (as you said), it will use less oil.
Rotorfixer
I know, I am not saying all engines are like mine, but you said ALL engines DFI or not, it just isn't true, like I said I am pointing out that there are 2 stokes (few) that don't fit into the bashing that was happening in this thread! I know 400:1 is in the idle range, trolling, but it does not EVER get an average of 50- 70 like you were saying. There are people who are going to be reading these forums to decide what engine to buy and they are not going to be getting all the facts right based on those statements. With my mix of driving I burn 1 jug per 100 hrs, that is what I was saying and using for comparison.
I said the E-tec gets worse economy (slightly, not saying way worse), it has better emissions....... either way that has nothing directly to do with oil consumption because it is not mixed with the fuel.
dingbat
Dude, we just did the math.
I burn roughly 2 gallons of oil for roughly every 10 hours of usage. Even if I changed my oil every 100 hours, which is nuts becouse I would be changing my oil every 10 days at the height of the season, I'd still go through 20 gallons of 2 stroke oil for every 1 gallon of 4 stroke oil and oil filter I used.
In 100 hours = 1 gallon of 4 stroke oil and a filter = $70
In 100 hours = 20 gallons of 2 stroke oil = $450
