Looper Carbs
Brew2
1986 Evinrude 140hp
Been fighting a fuel delivery problem for a long time and want to purchase a used set of carbs for my looper.
My question is....will a set of looper carbs from a 1993 140 fit on my 1986 140?
Thanks,
Brew
tashasdaddy
Re: Looper Carbs
go here and compare parts. also check johnson parts,
Brew2
Re: Looper Carbs
Thanks...but I think you forgot the link. Appreciate the input.
Brew
Brew2
Re: Looper Carbs
Forgot to mention that I'm assuming in my question above that the 1993 throttle bodies will come with the 1993 carbs.
Thanks.
Brew2
Re: Looper Carbs
Thanks.
I was actually planning on buy a used set (ie. carbs & throttle body) of carbs from ebay or someplace similar. The set available on ebay at to moment came off a 1993 Evinrude 140 and I'm trying to determine if they will "bolt onto" my 1986 140 without any issues.
I will certainly use new carb kits and give them a thorough cleaning before instalation.....just trying to determine if they will fit before I purchase them.
Cheers,
