loose belt merc. alpha 1 3.0
sonshine
I have a 2003 mercruiser alpha one.3.0 and my belt gives about 1.25 inches each way. Could that be why at higher speeds the motor revs up but doesn't go faster..sounds like its slipping. Is a belt change someone with basic skills could do? Thanks!
Re: loose belt merc. alpha 1 3.0
Ayuh,... Did you try Tightening it,..??
And,...
Nope, it'll have Nothing to do with your other problem...
sonshine
Thanks for your response. How do you tighten the belt and do you have any idea what might cause the boat to rev when push on throttle but not go faster if its not the belt?
Ayuh,... The alternator has a swivel bolt,+ an adjustment lock bolt, 1 on each side, loosen each, tighten the belt, then the bolts in the reverse order I mentioned 'em in....
The loss of propulsion is, My Guess, the Coupler is Bad...
It's mounted between the aft of the motor,+ the drive...
fishinpa
Or maybe a spun prop hub !
fish
sonshine
thanks..I can tighten the belt but any diagnostic type things I can do about the revving above 10 mph?? or do I need to find some money for the shop??
Fishermark
If you have a spare prop, try it and see if that takes care of the problem.
sonshine
Thanks, I'll try that..I'm new to this forum and I really appreciate the help getting me back boating!
Fishermark
When you get the problem solved, be sure to post your findings so others can benefit as well.
sonshine
I will do that..It has been helpful on other threads. Do I need to switch to another propeller (which I would need to get ) or just switch out the Flo Torq hub?????????
Oldskool
Before replacing the prop, you can simply mark a line on both the hub and the prop itself. After running with the drive engaged for a few moments, check to see if the hub and prop marking is still lined up. If not, then you have a spun prop/hub.
sonshine
Thanks for everyones help. It was Flo-Torq slippage..spun prop. I put a new plastic hub in and all is well. This forum was a huge help..THANK-YOU
