losing lower unit oil
south end
Hey people, I wanted to catch yall up on my problem with the lower unit on my johnson 15 horse. I replaced all my seals and o rings including the shift shaft o ring and im still losing lower unit oil. Can I have a crack in the gearcase? I dont see one, and oil doesnt come out unless its running.
Some would pressure test a gearcase to find leaks if there are any.
first, drain oil and pressure check the gear case.
it could be the 4 screws holding in the bearing carrier
could be the o-rings on the bearing carrier
it could be a seal
it could be a crack
The lower unit bearing carrier on a 15 HP is not held in with 4 screws !!!
Wave34
Mine was holding pressure and vacuum, and was still loosing oil by the bearing carrier oil seal. I'm working on that now.
