bigchunkytaco
- Feb 6, 2011
- 54
ok so after working out all my water pumping, missing parts and gear issues i got this '78 chrysler 35hp on the water pumping water ok (although the water stream is quite hot but didnt seem to overheat.)
i am unsure of what kind of power to expect from a 35 however i am certain it seemed to be quite low. was advised it should pull a ski biscuit but there is no way as is...
at first i thought it could be a fuel problem because it would die when i increased the throttle, i found a crack in the fuel indicator/ hose attachment plate on the tank so im patching that up tonight however cant imagine the fuel would prevent it from revving out before running dry.
however something is telling me its a low compression in one of the cylinders. the top was running 125psi which should be fine? but the bottom i cant fit my compression tester into, i got a reading of 25psi but am unsure if it was even screwed in all the way. it does feel lower wen i hold my finger over it, i cant see what else it would be. the spark plug also looked a little black but im unsure if its oil or burnt, does have good spark.
i havnt taken the head off as yet, as i was going to test it on the water by only connecting one plug at a time.. unless running the boat with a low/solo cylinder would not be advisable mechanically..
presuming the 25psi reading is correct would it just be the head gasket, or rings? or something more serious...?
any ideas from the wise iboat community would be greatly appreciated!
