BOSTINDIVAH1765
- Sep 14, 2002
- 4
hello everyone!!!! i am new to this.i have a 28' glen-l hand-made boat.it is powered by a mercury 90 h.p. outboard motor s/n#0a935062 model#1090726 yr.1987 i am running two west marine sea volts,dual purpose 745 batteries.mca 745, reserve 150 amp hrs.80 discharge cycles 200. grp 27.i came out of the fish house yesterday in gloucester.one bilge pump was inverted,which activated power.(was running whole time at pier.)isolator switch was on both.called sea tow for jump start.motor started after two attempts.boat ran halfway to beverly,mass approx 5 miles.lowrance x71 fishfinder showing approx 8.7 volts.lowrance global 2400 showing approx 7.6 volts.coming into beverly harbor both lowrances quit,vhf quit,running lights barely lit,made to mooring,motor stayed running for half hour.i shut it off,no start,everything dead.tach stuck at 4000rpms,fuel gauge on empty(about quater full.)battery meter on 8. i am currently charging batteries on 10 amp charger that i bought at west marine.does this motor have a voltage regulator????what should i do next?? i am electically challenged,and know virtually nothing about electricity.thank you for your time...
