Re: Low well pressure.
Tim, for better or for worse, the industry has deigned that the optimal spread between pump turn on and pump turn off should be 20 psi. This can be verified by the fact that all pressure switches that you buy have a 20 lb spread built into them. This is true whether you buy a 20-40 (probably cannot find one today) or a 30-50 or a 40-60.
The reason behind this is that someone determined that the optimal compromise between draw down volume, pump rest time and the fluctuation of pressure between the two, is 20 pounds.
The difference in fixture performance between 30 and 60 psi is just too great to make you think you are on constant pressure city water.
As an example, i have a shallow well pump that will deliver 6 gallons of water from max pressure (60 PSI) to cut-in.(30 PSI)......
