Re: Low WOT Rpms around 4800 manual states 5250 on 98 force 120hp
Reread the plate. There is a lot of confusion about RPM. The engine should be rated to run between 4500 and 5500 RPM at full throttle with the rated horsepower deveoped at 5250 RPM.
Generally, they like to run on the high side of the ratings but you are still within the range at 4800. If RPM has suddenly dropped or even graduallydropped, look as above, weight, and look at the bottom of the hull. Dirt, bottom paint condition, damage to the hull, worn propeller--any number of factors can cause loss of RPM, including a partially clogged filter , tank pick-up, quick-connects, etc.
