Lower cylinder # 6 foulng plug
trgill
I have a 1996 Envirude Oceanpro which is fouling the # 6 plug after each use. All other plugs are really burning good. It's a wet foul of oil/sludge that actually bridges the spark gap on ocassions. Compression is 110 psi on all cylinders. I checked the ignition coil resistance at ambient temperature and it was the same as the other 5 ignition coils. Spark plug wire resistance was good as well. Could the carburator be supplying to much fuel? Please let me know what to check next. Thanks
tashasdaddy
Re: Lower cylinder # 6 foulng plug
what horse power? have you tried completely swapping the #6 coil, with one of the others. if the problem follows the coil, you know the culpret.
iwombat
Could be a mis-adjusted float flooding the carb, but that should effect #5 and #6. How's 5?
I don't know a lot about the 6's but does #6 provide the pulse to the fuel pump? If so, you could have a leaky fuel pump diaphragm.
trgill
150hp. I swapped the number 3&4 coil to the number 5&6 to see if the problem follows the coil. Thanks for the suggestion. # 5 is really good, no problem there. I not certain if #6 provides puls or not but I'll research. Thanks.
Faztbullet
If the sludge has a little greyish look to it, pull head and replace cylinder
o-ring. These engines will still have great compression and run fine on top end and be missing a third of the o ring.
trgill
Thanks for the reply. No grey color to sludge, just black oiley looking.
