Lower End Oil option
Ken Barber
Probably an easily answered question:
I have left over gear oil from a car - GL-1 90 Gear Oil.
Can I use this in my lower unit - 89 Evinrude 140 HP?
I now use West Marine lower unit oil. I know I am getting a little water in the lower unit and I want to change frequently till I can lay it up to get it fixed.
Would the GL-1 90 gear oil work?
Daviet
Re: Lower End Oil option
It MIGHT work, but I would suggest using lower unit oil for marine application.
kenmyfam
Use the correct stuff and have done with it.
Did you change the seals on the screws ??
Vic.S
GL-1 does not contain the extreme pressure additives that GL 4 and GL-5 do. Outboard gear oils are to GL4 or 5 specs plus corrosion inhibitors to guard against the effect of water intrusion.
Perhaps therefore not a GL 1 oil unless for very gentle use.
Ken Barber
Thanks guys. I will not use the GL-1 90. I appreciate your help!
petryshyn
as kenmyfam says, change the drain/fill plug gaskets. That may be your only leak...
Ken Barber
