McGR
- Jun 19, 2004
- 666
After discovering milky lower unit lube, last night I pulled my lower unit on my '76 Johnson '85hp to replace the prop and driveshaft seals and perform a subsequent pressure test. After installing the new seals, I noticed that the driveshaft seemed like might be taking excessive force to turn, even with the waterpump removed. I can't turn the driveshaft with one hand. I can turn the driveshaft with two hands or with a channel lock pliers. Is this sort of resistance to turning normal for this type of lower unit? This lower unit is a hydraulic/mechanical type as opposed to purely mehanical, so it pushes a pump in addition to the gears. Nonetheless, it seems to me the force required to turn is excessive. I hope I'm wrong. Is there possibly some sort of torque spec. for the force required to rotate this lower unit? <br /><br />Any input is greatly appreciated.
