lower unit conversion chart
skip44820
I searched my question on here before asking and cannot come up with the solution. I have a 1989 28 hp johnson and need a lower unit, I need a conversion chart of some sort to locate one. Somewhere I found info that a 25 to 28 hp ser. no 0432812 20 in. long shaft 1989 to 1996 will work, and I was hoping someone here could verify this info or point me in the right direction. Thanks in advance as always.
there is no "conversion chart"
start going thru the parts lists like everyone else.
Correct.-----These 28 HP " specials " were 30 HP models marketed to clear surplus lower units / midsections.-----So any of those 1989 to 1996 will work.-----Changing a long lower unit to fit on a short midsection is easy.----Your location ?
