Lower Unit Drain/Fill Gaskets
arnettjs
Hi Everyone,
I am looking to buy (off Iboats, of course) the o-rings for the drain and fill screws for the LU on my 1992 Johnshon 115hp VJ115TLAND. The part number, I believe, is 0333572. Any help would be greatly appreciated!
Thanks,
Jeff
Texasmark
Re: Lower Unit Drain/Fill Gaskets
I buy from my local dealer and while there pickup several sets. Then when I need a set, I have them and don't do something stupid like put the screws back with the old gaskets because I don't have any new ones and want to finish the job right then.
Mark
tashasdaddy
iboats, sierra # is 18-7145, buy 10, so you have then. they are one time use only items.
ezeke
There are two kinds of fill vent plugs, one uses the o-ring and the other uses a flat nylon washer. Be sure that you have the right seal.
arnettjs
Thank you very much, order placed via iboats!
