lower unit is sqirting water on muffs
astro2724
my lower unit is spraying a tiny bit of water where it is put together.Should i be concerned with this?it is just a little tiny stream.Looks like a tiny pin hole.thanks.
ob
Re: lower unit is sqirting water on muffs
As long as the joint bolts are tight ,no worries.Make sure your cavity drain leakoff holes are clear.
