Texasmark
- Dec 20, 2005
- 14,798
Re: Lower unit leaking...can't get prop off!
The thrust washer is in front of the prop and keeps it from climbing up into your LU. You can rig a chain around the prop and use a 3 pronged flywheel puller to put some tension on it. No heat and no banging on it as you have seals, gears, and bearings you don't want to mess up. Just keep at it, lots of penetrating oil. When you get it off and finish your business, put some grease on the prop shaft splines and you won't have this problem again. Removing the prop once per year in high corrosive environments will help too.
Mark
Mark
