2004 Alpha I Gen II
Had a lower unit lube leak last boating season (had to refill the resevoir several times over a couple months).
Removed the unit, built pressure tester, and tried it last night....held 10 psi overnight.
Bought a vacuum (brake fluid) tool today and will try to adapt that to my tester tonight to check with vacuum.
Question is....if the vacuum holds, where do I look for the leak?
Anything else a fella should be checking??
Thanks in advance.
Brew
Thanks in advance.
Brew
