Lower Unit mercury 1967 950SS
dutchweel
I am not sure if I should start a new thread?
Current issue/problem:
Everything was going fine until I struggled with the shift shaft alignment.
After several tries making sure the upper and lower shaft were connecting, I
kept having problems testing the gear shift. It won't come out of forward?
I noticed that when the lower unit was off that the shaft will rotate left/right.
Before attempting again, is there a way to make sure the shaft is in the right gear position? ie. should I rotate the shaft all the way counterclockwise or clockwise?
Thanks for helping.
Laddies
Banned
Re: Lower Unit mercury 1967 950SS
If you rotate the shaft with a pair of pliers you will find that there are 3 detent positions find rev that is the place the prop shaft is locked both ways, then put the engine rev. in gear and install the unit
dutchweel
Hello,
I finally got everything together and got to the point to start.
I have a flush device connected and ran the motor.
I am only seeing a trickle of water come out?
I assume this is not good. ANY ADVICE?
THANKS
dutchweel
It is coming out of the water hose in the cowling. This is where it has always been coming out.
