Lower unit oil
Ronniewhite
I changed the lower unit oil on my 2000 Johnson 25hp 3cylinder today because I'm tarping up my boat for the winter. The oil was like a yellow and really thick and creamy. It took like 15min to drain. It was minus 1 outside. Was the oil like that because of the cold temperature or was it because there's water getting in and it was half frozen. It had new oil in it in the may and I used the motor for fishing about once a week.
saltchuckmatt
If you still have it see if it's separates. Probably needs pressure testing. Might want to wait until spring if you can't pull the lower and get it into a heated space.
Ronniewhite
No I don't have it. It was like a Cadbury Easter egg. Those creamy ones they have at Easter time. That's what the oil was like
Crosbyman
had the basic same issue on my 75 ETEC 2-3 years ago. I assumed the GC was the problem so I dropped the GC and took it home for the winter to do pressure and vacum tests .. in a warm basement :) all went perfect no leak ???
Ended up being a "reused crush seal" issue because I refilled the GC and stopped using " used " seals. never had issue come up after.
If you have no mono line tearing up the prop shaft seal I would refill & reseal with new crush seals and run a few trips with it. Recheck the oil for infiltration if... you don't have a pressure/vacum tester.
https://www.bing.com/videos/search?...D84144AD90360F195315D84&view=detail&FORM=VIRE
Ronniewhite
Actually I've probably changed the oil 4 or 5 times and I never changed those seals. They looked good so I thought they were good. They are those clear little rubber seals right? I will make sure I get some new ones before I run it in the spring.
Crosbyman
round white washers (seals) that fit the bolt... not rubber... more like white nylon plastic...
very common outboard part
don't use hardware store stuff because the plastic material is much harder
clemsonfor
Yellow as in honey or amber colored? That's what oil looks like when it's clean and new. Now if it was milky yellow and opaque it sounds like some water is getting in.
Ronniewhite
It was not the same colour as the new oil. It would be like the color of that creamed hunny that comes in a little plastic container.
Vic.S
The oil should remain "clear and bright" but perhaps just a little darker in color.
If it is turbid or milky looking it indicates water is getting in
It took a long while to drain because it was cold ......... warm it up a bit and it will drain faster. Warm the new oil before filling too and the task will be much easier.
Vic.S
Sometimes you will come across drain/ level screws with O ring seals but the screws for them are different.
If there is a recess on the underside of the head O rings are correct.
If the underside of the head is flat the flat plastic ( nylon??) washers are correct.
If you use O rings on the latter you will over-compress them
If you use flat washers on the former the head will stand proud and you may not get a good seal
Chris1956
Coated paper gearcase gaskets are the right ones for most applications. The nylon can be too hard to seal well. I never seriously tried the oring ones.
You need to dig the remains of the paper ones out of the gearcase when changing the oil, as multiple partial gaskets can leak. Amazon and other places have them in bulk.
Mercury Outboard gaskets also fit Johnson/Evinrude outboards and MerCruisers. Not sure about Yammies. as they require an adaptor to fill the gearcase with oil.
airshot
Depending on the mfgr of the oil and whether dino oil or synthetic will make the oil different colors. I use full synthetic which is like a very light honey color, but the straight duno 90 weight is much darjer almost like molassis or pancake syrup. I also have a blended gearboil that is a darker amber, so all depends !!!
dingbat
Not a fan of the old style slotted screw drain plugs or paper gaskets for the reason you noted above.
Switched to “new style” OEM Hex head screws with nylon gaskets and never looked back.
Could see getting the proper torque on a nylon washer being a problem using the slotted screw. No problem at all using an Allen wrench.
Evinrude OMC New OEM Fill/Drain Plug Screw, 0982851, 0912625, 0307551​
Johnson/Evinrude/OMC New OEM WASHER 0311598​
Crosbyman
me.... I prefer slotted because hex heads are easy to strip... never went back to hex heads
Trying to remove s tripped he head is a real pia.
Have to agree.----I like slotted heads.----Soft stainless hex heads are easy to damage / strip.
airshot
The trick to the slotted screws is make a screw driver that fits.....as a retired tool maker, I saw the need for a proper fitting blade and one that is hollow ground. Also have a shank that is square to attach an open end wrench for leverage. Made my tool many years back, it doesnt bugger up the slot and will break loose the most stubborn screw.
Chris1956
Gee, I use a hand impact driver. They come with various widths of slotted screw driver bits. If you use the impact driver correctly, the plugs do not strip.
Lou C
I’ve been using those for years on my Cobra they are much easier to deal with than the old slot style. The hex head Allen style won’t strip as long as you use the right size….keep in mind there are US size Allen fittings and Metric…
Also ALWAYS replace those white fiber sealing gaskets! They get grooved when tightened & will often leak if reused.
Crosbyman
I think BRP uses US size 5/32 Allen on OEM ...but I have managed to strip them. boils down to preferences I guess.
