Lower unit pressure test
IS-217
Hi all.
2008 starcraft I/O 4.3L merc.
I am wondering if I can do a pressure test on my lower unit while its mounted on the boat. I redid some seals and a new impeller this spring because there was a little bit of water in the gear oil. After reinstalling it on the boat a friend asked if i did a pressure test but i did not. Now that its on the boat i dont want to risk ruining the gasket. So my question is can i do a pressure test while on the boat. I haven’t filled up the gear oil yet. My inboard does have an oil reservoir and ive read if so i cant do the test on the boat. Im curious if this is true or not. And if true why can’t i do the test? Isnt the oil line sealed at the reservoir?
Scott06
Hi all.
you might be able to by clamping off the line tot he reservoir.
The gasket for the outdrive is like $10-15... pretty cheap to know it holds pressure. if you hadn't done the shift shaft seal I would look closely at that. I got a fishing line in prop seal of my 2004 vintage gen 2. So I re-sealed it given the age. The only seals that were close to being gone were the shift shaft seal.
