Lower Unit problem
izuizme
I need some machanical know how..
I NEED TO REMOVE THE BEARING HOUSING on a 1979 Johnson 200txl79a. There is an oil leak and it won't hold pressure. So I want to replace the driveshaft o-ring # 5 on diagram (part #0314728) and driveshaft oil retainer's #7 on diagram (part #0321453).
The 4 bolts came out easy but the housing seems to be frozen. Prying it out may damage lower unit. Thanking U in advance..!!
Joe Reeves
Re: Lower Unit problem
That housing is simply a tight fit. Use two large screwdrivers, one on each side to wobble it up and out of the gearcase.
Gary H NC
Soak it overnight with some PB Blaster and give it some light taps with a hammer...
James R
It is quite common that the bearing housing will not come out. I usually have to apply slow but considerable heat to the casing to make it expand before the housing will come free. Best done by a professional.
