OhWellcraft
 - Jun 22, 2007
 - 277
Hello to all,
I have a 83 evinrude 200 hp. model #E200TRLCTD. Took the boat out on Sun to make sure everything is okay as I am headed to Lake Powell this weekend. Seems to be running fine, got home and thought I might check gear lube in lower unit. To my dissapointment there seems to be a slight bit of water in the lube. There can't be much because almost the exact same amount of lube came out as I put in a month ago when I replaced the water pump. I put new o-rings on the drain and fill screws when I filled it. My question is how much is involved in replacing the prop shaft seal only for now then when I return I will have the lower unit re-sealed by a mechanic. I am quite mechanical and have two manuals but just don't feel like I have the knowledge or the tools to tear down a lower unit . I thought I might try to replace the prop shaft seal if it is as easy as it looks to be but neither of my manuals covers this only. The mention is made after the carrier etc. is already removed. Can a person grab on to it with some needle nose pliers and pull it out then replace it, or is it locked in there some how? Also do you think I could replace the lube 2 or 3 times through the week and be okay? I know that isn't the right way but I can't just cancel with less than a week till we leave.. Any thoughts or advice would be GREATLY appreciated. As always thanks to all on this great site. Brendon
