Hello there.
I own a Jeanneau Leader 650 with 1992 Volvo Penta 431A engine DP-A1 sterndrive installed.
She stays in salty water all year long.
Bought her 2 years ago, with engine flooded and blocked.
Rebuild engine, changed elbows, exhaust manifolds,rebored cylinders,oversized pistons/rings/bearings/
valves/seats/guides/rebuild starter and alternator.
Worked fine for 2 years.
Last month, strange noise while steering engine running.
Took engine off, took stern off, a very little bit off water in upper bellow, and fund rear oil seal output shaft installed lips forwards instead of rearwards, changed output shaft 2 rollbearings and oilseals, U-joints.
I please need to find a servicing list about all operations I should provide to this engine and sterndrive.
I read about a pressure test on the sterndrive, but I do not feel confortable to applicate 60 PSI to 18 years old oil seals.
Except routine maintenance I do not have any list of what and when parts should be inspected and remplaced.
I do not know how frequently shall I remplace bellows for exemple.
Same for water pump impeller.
I know those VolvoPenta models have been spread in the United States, less in Europe , and informations are hard to find.
Any help will be appreciate, thank you , Paul.
