ajgraz
- Mar 1, 2010
- 1,858
This is more about wiring than about the motor, but I figured this was the best subforum for this...
1979 3 cyl 70hp Mercury on a 15' trihull. Run in saltwater. I have had to patch up the aging, corroding internal engine harness more times than I can count, and am getting fed up with that. Final straw is that there is now an intermittent short inside the female connector.
This is kind of a bastard-child Merc connector, only used on 1977-1979 3 cyl motors. Exact OEM replacement is high-priced new and hard-to-find used in decent shape, and AFAIK no one (like CDI) makes an aftermarket replacement.
Anyways, I'm ready to make my own internal harness for this motor. Shouldn't be too difficult, I don't think; just wires and ring terminals:
Already planning on Ancor marine wire (10-12AWG red, 14-16AWG all others) and heat-shrink butts and terminals as I already have most of what I'd need; but I don't want to spend $$$ on (CDI) "universal" boat harness/connectors if I can avoid it.
So here's my questions:
1) What kind of connector(s)?
Any reason I should not use automotive GM / Delphi / Packard Weatherpack connectors between the internal and external harness?:
http://www.weatherpack.com/
Would like to use these because I already have all that for automotive work. Also I can do a better job wiring in my jury-rigged add-on temperature sender. Any better suggestion for inexpensive connector(s)?
2) Where should I put the connectors?
Current OEM connection is inside the motor cowling, bolted to the side of the head. I may bolt the cut-off OEM connector back in place, because it is molded so as to also guide/hold the battery cable into the cowling. Also, I do not want to have to extend the external harness. So my choices for where to put the Weatherpacks are:
a) about 4 to 6 inches outside the cowling (basically hanging "free air" above the splashwell; will get splashed)
b) about 2-3 feet outside the cowling (where I can hide them up under the stern cap, although now they're in the same space as where the vented portable fuel tank goes)
c) halfway to the control box, where they are tucked under the gunwales with all the other supported wiring and control cables (no splash, no gas fumes).
Which location would you choose, and why?
