bruceb58
- Mar 5, 2006
- 30,610
I wasn't thinking you would use horizontal guides. You can use the same concept with a vertical guide screwed into the vertical pole. Of course if your welding skills aren't up to snuff than you won't be able to do this. I have a 220V welder which is what you would really need for my style.
My tubes are 3" and 2 3/8" with 1/8" wall thickness.
My guides are just guides. They don't do anything to precisely center the boat. They just help when it is windy. There is a big gap between them and the boat so that my cover fits between.
AS far as your tiedown goes, replace the rope with a wide webbing type tie down and you will be fine.
