Re: manifold filling with gas/low compression
Thanks bondo - Your right I forgot to open the throttle on the compression test. It's a 4 pt. engine stand, stable enough.
sns~u r a brave man! stable enuff ain't enuff for me!!! not for an L6!!
Specs on this gm 250 165 hp say compession should be 140 psi. and I have had the dist. out because I manually primed the system with the oil pump because I had a slack lifter which is ok now. With valve cover off set mark on tdc just before the intake starts to open. points at 16* plugs .035 fuel pump line into bucket good strong sguirts. I'm going to try a few things and start over here. New exhaust gasket rebuild carb new plugs they came with the motor anyway. Level engine stand. I will follow up with you guys on my progress. Thanks for all the pointers and suggestions. very appreciated! p.s. great responses
sns sez"
"With valve cover off set mark on tdc just before the intake starts to open."
NOPE, sorry!
wrong as u have it stated here: that TDC is 180 out of phase! why do u want the spark plug to fire just before the intake starts to open... ????????
u want the TDC where compression is building. that is where u want the plug to fire. and both valves will be
closed! u want to initiate ignition to allow flame front probagation to take place sufficiently so that combustion chamber pressures on the piston's crown maximize at the point the rod's arm = maxim leverage potential to the crank!
that is why u set timing at BTDC point on crank. so u can get piston pressure to build. therein lies torque.
so if u r in fact 180 out, as u have stated... pull all plugs. use a remote starter switch or build one. dont do it on the starter. if u need to build got auto parts store get push botton starter switch, some 14 guage wire and 2 clips. hook it up to solenoid S and bat +. now thru switch u r hot to starter. now u can click, click click the engine over... a tweak at a time. then with remote connected and ur tie not in water pump pulleys... lol,
put ur finger on hole #1. now click click the remote until #1 comes up on compression. if u miss it first time, nbd. just try it again til u get into the groove. then tweak it making compression, [warm pressure will blast out of hole indicating u are on compression stroke] get it to 6 BTDC or what ever the spec is. this is where ur mechanical side of ur engine needs to be.
u may only be able to get it close. the starter is powerfull with no plugs in. be sure they 'are' out! so note direction harmonic balancer turns. stop short of 6 BTDC. and somehow, screwdrive, bar or? turn engine further by hand to 6BTDC. i have put bolts into harmonic balancer or unloosened pulley belts, backed out bolts to lower crank pulley, used bar inserted between the 3 and then turned crank over by hand. but do it in its natural direction. if u miss and go over, then back down a bit and then crank it up to 6 BTDC.
she'll never run if ur 180 out of timing phase....
now then... follow my advice and go set the distributor as i am suggesting. if u have fuel into intake and all else is as it should be... expect it to run.
"we r rootn' for ya!!"
let us know
regards
lakester
