bajaunderground
- Apr 18, 2008
- 1,401
Re: Manifolds and Risers - guess I'm replacing??
Grab a tape measure and measure from bottom of oil pan to about 3" above 'V' then measure from gasket mounting point to bottom of deepest part of pan...looking at mine, there seems to be enough room? On the 4.3L I have no idea with out measuring. Bondo's usually correct. I will say, pull the drive, take out rear beanch seat backrest, loosen the engine mounts and cherry pick it enough so it's high enough to drop pan...you might not even need to remove bench seat back? You might just need a few inches?!
Thanks on the house. Best part is there's 2 lakes within 15 min drive to the ramps.
You think there's enough room to drop and change out the oil pan??
