Good Trout To You Sir
- May 22, 2018
- 85
Model: E4BRECJ (1998 4HP). This is a F/N motor.
Acquired from original owner who used it for 6 years and then forgot about it for 15 years.
Trying to perform assessment, but am unfamiliar with tiller twist throttle type. Twist grip throttle has very little play in it. Also, decal is missing for indication of slow ==> fast. Throttle cable appears to be in position of least tension. Is this WOT position?
Recoil starter is not engaging flywheel consistently. Could this be safety mechanism to prevent start start in neutral gear with high rpms?
Have lubed cylinders and checked lower unit oil. Now would like to attempt start -- or at least compression test. For both exercises I need to figure out how to adjust throttle ----- any advice?
